HELP! Cannot find datasheet!
Discussion in 'General Electronics Chat' started by peaac, Sep 17, 2011.
  1. peaac
    Sep 17, 2011
    11
    I have a 7-segment display (has two decimal point on each side) the only numbers on it are M72/K312B. I cannot find any datasheets for it! Can anyone help me?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Don't worry too much about not being able to find a datasheet.
    If you have a meter with a diode test function, you can quickly determine which pins will light up which segments, and which pin(s) are the common cathode or common anode connections.
  3. VoodooMojo
    Nov 28, 2009
    503
    53
    It is a common anode
    pin 3 and 14 are high, the rest will be low inputs
  4. peaac
    Sep 17, 2011
    11
    Thank you :)
