Help! Can you wind a generator with steel wire?
Discussion in 'The Projects Forum' started by chasone, Mar 18, 2009.
  1. chasone
    Mar 18, 2009
    Ok, I am helping a (nut case) friend build an axial flux generator for his wind turbine. He just knows that if he substitutes steel or iron wire for copper wire that he is going to generate more electricity.
    I know he's wrong. He just knows this is some "secret" being kept from the public like Teslas' car.
    What can I tell him to expect?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A great deal of frustration.
    The steel wire is hard to handle, hard to insulate, and resistive enough to lose a lot of energy as heat. That can lead to the whole device burning up a relatively modest power levels. Using aluminum wire is hard due to the difficulty of making joints, but would be significantly better in performance.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Steel has nearly 10 times the resistance as copper. If his goal is to waste power or make a heater, he is on the right track. If he wants to "up the ante", he can go for stainless steel, 53x the resistance of copper, or nichrome wire, 65x the resistance of copper. For metallic conductors, as their temperature increases, the resistance also increases.
    Aluminum has about 1.55 times as much resistance as copper; thus would be a much better choice than steel. As Beenthere implied, oxidization of aluminum is a big problem.
    Silver has about 94% of the resistance of copper, but it's cost is prohibitive.
    Gold is about 1.4 times the resistance of copper. It's used in electronics as a plating because it is so stable; it oxidizes very slowly.
  4. mik3
    Feb 4, 2008
    4,846
    63
    If he is not professional it would be better to buy a generator and attach it to the wind turbine. It will be more efficient because it is designed by professionals.
    Otherwise, if he does it for hobby he can experiment!!:p
  5. thatoneguy
    Feb 19, 2009
    6,357
    718
    There is a company that sells small gauge, coated steel wire for experimentation to people like him. I forgot the URL, but found it interesting.
    I remember a discussion on some blog about them a while back for selling 'bad wire", since their steel wire didn't outperform copper in the turbines they made, which their ideas showed it should have performed better. I believe a google search will find that discussion. I'd look for it, but I don't want to damage my brain intentionally.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    They probably sell the same stuff to people trying to make Stanley Meyer over unity HHO generators.
  7. KL7AJ
    Nov 4, 2008
    2,047
    295
    I'd say humor the guy. Nothing tells the truth like abject failure. :)
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Googling "axial flux generator" brings up more commitment than science. Awfully fancy name for a PM alternator.
  9. thatoneguy
    Feb 19, 2009
    6,357
    718
    I did it.
    At current rate from the grid, this turbine would produce $3,000 worth of electricity per year. Yet, the entire set, mast, turbine, blades, is only $100,000!
    How many places have continual wind speed over 5mph, enough to average over 10mph?
    Free Power!
  10. DedeHai
    Jan 22, 2009
    39
    In addition to the iron beeing less conductive: it is olso ferromagnetic, short circuiting the magnetic flux. the performance of such a generator will be below awful.
  11. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    At a guess, it's an interest in the magnetic properties, rather than the electromagnetic ones that prompts the interest in steel wire.
