Help Calculating Rb Collector Emitter Feedback Bias
Discussion in 'General Electronics Chat' started by Ronscott1, Nov 9, 2009.
  1. Ronscott1
    Nov 5, 2009
    15
    Hey. I am designing an amplifier using collector emitter feedback bias. I am using a 2n5088 transistor, which has a minimum gain of 300 @ 1mA 5V Vce. I have Rc calculated to 3.6kOhm and Re calculated to 900 Ohm. How do I determine what value of Rb is needed?
  2. Ronscott1
    Nov 5, 2009
    15
    Also when calculating the value of Re, should I have used the value of Ic given in the data sheet?
    Thanks guys
    Ron
  3. Jony130
    Feb 17, 2009
    3,991
    1,116
    Maybe you post the schematic and tell us more about supply voltage, voltage gain etc.
    But in general
    Rb = ( Vcc - (Vbe+Ic*Re) / Ib
  4. mik3
    Feb 4, 2008
    4,846
    63
    A circuit schematic will clear things up. Also, what are the specifications of your amplifier, like gain, input-output voltages range etc.
  5. Ronscott1
    Nov 5, 2009
    15
    Hey guys its ok I figured it out.
