OK, I have no idea what I'm doing; but would greatly appreciate your
help! but I decided I wanted to build my own circuit. Its a Low Voltage
Battery Disconnect. Heres the schematics, and I tried gathering all the
parts I needed using alliedelec.com... but I am unsure on a few. (see after
pictures)
Not exactly which part for theeese.
U2: 78L05, 78M05, or 7805 5 Volt regulator
I have no idea.
http://www.alliedelec.com/Search/SearchResults.aspx?Ntt=78M05&N=0&Ns=Popularity%7c1&i=&Ntk=Secondary
http://www.alliedelec.com/Search/SearchResults.aspx?Ntt=78L05&Ns=Popularity%7c1&i=&N=0&Ntk=Secondary
D1-D6: 1N4148 switching diode
I see they range from 100-500mA, different voltages.
http://www.alliedelec.com/Search/SearchResults.aspx?N=0&Ntk=Primary&Ntt=1N4148
C1: 0.001 mF ceramic disk capacitor
50 or 100 vdc? They all seem to be the same :/
http://www.alliedelec.com/Actives-and-Passives/Capacitors/?N=4294821930+4294840716+4294827505
C2-C6: 0.01 mF ceramic disk capacitor
what voltage rating? 16vdc is my guess here... but not exactly sure.
http://www.alliedelec.com/Actives-and-Passives/Capacitors/?N=4294821930+4294840716+4294855885
C7-C10: 0.1 mF ceramic disk capacitor
16vdc aswell?
http://www.alliedelec.com/Actives-and-Passives/Capacitors/?N=4294821930+4294840716+4294924622
C11: 22 mF, 16 V electrolytic capacitor How many Ohms?
http://www.alliedelec.com/Actives-and-Passives/Capacitors/?N=4294821930+4294821309+4294839100+4294827693+4294924977
VR1: 100K trimmer pot, 10 turn variety preferred
A lot of results, Just get one 10 turn? Would I have more precise measurements with say, a 25 turn? If thats the case, I would opt out for that instead.
http://www.alliedelec.com/Search/SearchResults.aspx?Ntt=100K+trimmer&N=4294966088&Ntk=Primary
I'm fairly certain these ones below are what I need.
U1: 1458 dual op-amp
http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=2880379&MPN=LM1458N%2fNOPB
Q1: IRFZ34
http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=2731410&MPN=IRFZ34NPBF
D7: 1N4001 1 A diode
http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=2660001&MPN=1N4001
F1: Automotive fuse (see text)
http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=798SPEC&MPN=0001.1014
http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=7980586&MPN=0031.3571
S1: DPDT toggle switch
http://www.alliedelec.com/Search/SearchResults.aspx?N=0&Ntk=Primary&Ntt=DPDT+toggle+switch
R1-R4: 100k 1/4 W resistor
http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=2964745&MPN=OK1045E
R5,R7: 1M 1/4 W resistor
http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=2966331&MPN=OK1055E
R6: 1K 1/4 W resistor
http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=2964741&MPN=OK1025E
R8: 22 ohm 1/4 W resistor
http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=2966568&MPN=OK2205E
pictures)
I have no idea.
16vdc aswell?
Q1: IRFZ34
