Would you buy or recommend to a beginner this oscilloscope as a cheap option...
It's Russian, so if the text bellow looks odd it's because it's translated.
Oscilloscope C1-118A is designed to monitor and measure the electrical
signals with an amplitude of 5 mV - 400 V and a duration of 80 ns - 0.5. TV-sync. Due to its small size and low cost, the unit C1-118A is used in the repair of electronic services radioaparatury, amateurs and educational institutions.
- Vertical deflection
- The bandwidth of 0-20 MHz
- The rise time of 35 ns HRP
- Odds
- deviation of 5 mV / div - 5 V / div
- Sweep 0.02 ms / div - 50 ms / div
- Limits of error of deflection factors sweep ± 4%
- Input resistance, capacitance 1 M, 30 pF
- Calibrator
- Output voltage: a rectangular pulse amplitude of 12 V (2% error)
- Effective screen 60 x 80 mm
- Power 220 ± 22, 50 ± 0,5 Hz or 60 Hz ± 0,6
- Power consumption 28 VA
- Dimensions 120 x 210 x 300 mm
- 4 Weight kg
