Hi everyone,
I would like help building an electronic circuit. The circuit consists of a charging unit (4.2v max output). A rechargeable Lith-ion battery and a light source.
The light source is a white LED (single) with the idea that the LED will be connected to a PCB that supplies power to the LED from the attached battery. The charging unit is to be detachable, rather like a mobile phone charger except in my case its a series of solar panels connected in series/parallel i.e. two pairs connected in series and then joined in parallel to give approx 4.2v output.
I am happy with the charger itself but struggling to understand what is required on the PCB in order to connect the charging unit so that it can start to charge a lith-ion battery and then what is required between the battery and the light source. I presume a resistor? a capacitor? etc. Any suggestions where I can obtain the necessary components would also be very useful.
Thank you
Thank you
