Help Building biofeedback for muscle sensor / EMG with arduino
Discussion in 'The Projects Forum' started by stregoi, Nov 28, 2015.
  1. stregoi
    Jun 12, 2014
    Hi hope someone can help me achieving this build, i am a newbee in electronics.
    I am working with a research project in my hospital department, where i have to monitor the back muscle activity in scoliosis patients.
    I have to record the EMG activity 4 different places ( 4 electrodes/channels), for 24h for like a whole week.
    I have in mind to use an Arduino ( as small as possible ), some electrodes, and somekind of external storage, an SD card maybe.
    i have been looking around in the internet but almost all projects involving EMG sensors are single channel and not storing in a card.
    So please any advice on how i can approach the project ?, what will i need and eventually some suggestions about what i am intending to do.
    Any help will be appreciated.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I would be very careful with anything attached to a patient. If not FDA certified you could be in a whole heap-o-lot of trouble.
    I would start with four single channel sensors if that is all you have. What kind of interface do these sensors provide? Can you provide a link to a datasheet?
    This link might help. Note the use of 9V batteries, an important safety precaution.
    http://www.instructables.com/id/Muscle-EMG-Sensor-for-a-Microcontroller/
  3. #12
    Nov 30, 2010
    16,704
    7,354
    I don't see how a 5 volt sensor array can hurt anybody, but a lawyer probably can. Be sure to get FDA approval BEFORE you design it.:rolleyes:
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I worked with machines attached to patients and the FDA process is both meticulous and rigorous. Battery operation gives a significant advantage until there is an oxygen tent involved and then there is a whole other protocol.
  5. #12
    Nov 30, 2010
    16,704
    7,354
    I assumed this meant the subject wouldn't be in an oxygen tent and the machine would use batteries. Maybe I was wrong.:oops:
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I did not assume battery operation, but since the probes are required to pierce the skin I think it would be advisable. Many non-invasive instruments use AC supplies compatible with hospital outlets that limit leakage current and other things. Blood pressure and respirators are two examples.
  7. stregoi
    Jun 12, 2014
    Thanks for the answers guys .. sure i will apply for approval before starting my project, i have to be sure that i can make the thing though. i was thinking about using Myoware as the EMG sensor. is it a good idea ?
    but connecting 4 of myowares + SD card reader + arduino, is my issue .. and/Or is it enough ? is their a smarter wahy to do that ?
  8. stregoi
    Jun 12, 2014
    This what i came with so far
  9. Alec_t
    Sep 17, 2013
    5,979
    1,138
