Help - Bipolar TTL Circuit
Discussion in 'Homework Help' started by mashour, Jan 13, 2007.
  1. mashour
    Jan 13, 2007
    I need help with the following homeworkd question:
    Implement the following function using bipolar TTL circuit:
    ____________
    F=(A+B) * (C+D)
    Use NAND - NOR configurations to draw the circuit. Remember to use multi-emitter transistor for NAND function and parallel-driver transistor for NOR function
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Can you post up your work and indicate where you're stuck?
