help> auto off switch?
Discussion in 'The Projects Forum' started by kchan, Jun 28, 2007.
  1. kchan
    May 14, 2004
    12
    hi guys, im thinking of creating a switch for my water tank and water pump. i saw a thread here almost the same and its about moist sensor.
    can u guys give me ideas about this and if possible, a diagram for the circuit? thanks
  2. cumesoftware
    Apr 27, 2007
    1,330
    11
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Kchan, what do you want to accomplish? Do you want the pump to turn off when the water reaches a certain level? What sensor(s) do you have? Cumesoftware's suggestion will work for a time-based turn-off, if that such what you are seeking.
  4. mozikluv
    Jan 22, 2004
    1,437
    u can check my post on this. that might be the thing your looking
    moz
  5. kchan
    May 14, 2004
    12
    hi all, thx for the replies
    @cume sorry for the poor information i give, i already have an auto on/off timer based switch but it doesnt function well as sometimes the water is weak and the tank wont be full in a time period i set.
    @thing yes thats what i wanted, but i dont have any sensors and etc yet. i also know only basic in electronics so i hope if u guys have a schematic, the components wouldnt be so hard to find coz i dont know how to get replacements parts
    thank u
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    If it were me, I'd use a float switch. Easy to fabricate or to buy, easy to adjust.
  7. kchan
    May 14, 2004
    12
    ok i think its kinda hard for me i might just try and keep looking if there is any available "kits" for this. thanks
  8. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    http://www.aquahub.com/store/doityourself.html
    These will work for fish tanks, cisterns, et al. You might want to double-check temperature tolerances if your tank is a hot-water heater. The same company has float switches for as little as seven dollars.
    Aquahub has many competitors; a little shopping around should net you just what you want. Try the search engine term "float switch."
  9. kchan
    May 14, 2004
    12
    thanks man from those pics, i got some ideas and i might try creating my float switch
  10. cumesoftware
    Apr 27, 2007
    1,330
    11
    Normally float switches are used for such applications. They are more reliable and durable, and yet simpler than electronic sensors. It is pretty common to find one in water tanks and reservoirs. It is better than a timer, since it relies on water level. I didn't know what you were looking before, so, sorry for my other suggestion.
