Help - Amplifier with BJT and Mosfet
Discussion in 'Homework Help' started by Alfa_ET, Nov 26, 2011.
  1. Alfa_ET
    Feb 26, 2011
    17
    Hi everybody,
    I need help in this exercise of electronica. I'm not sure about the results I got. Please see my resolution and tell me where I am wrong.
    Exercise:
    http://img7.imageshack.us/img7/2826/digitalizar0001pi.jpg
    Resolution part 1:
    http://img259.imageshack.us/img259/2006/digitalizar0002d.jpg
    Resolution part 2:
    http://img832.imageshack.us/img832/4278/digitalizar0003v.jpg
    Resolution part 3:
    http://img12.imageshack.us/img12/3479/digitalizar0004wd.jpg
    Resolution part 4:
    http://img522.imageshack.us/img522/3710/digitalizar0005im.jpg
    Thank you all
    greetings
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Keep in mind for the PMOS case the source must be at a higher potential than the gate.
    You have calculated for the PMOS
    Vgs = 3.61V and Vg = 3.64V
    Thus Vs2 should be 3.61V above Vg2.
    Hence I would think Vs2=3.61 + 3.64=7.25V rather than 0.03V ....
  3. Alfa_ET
    Feb 26, 2011
    17
    Yes you are right. And about Vdrain 2?
  4. Alfa_ET
    Feb 26, 2011
    17
    the gain of first stage is -gm1*Rd. And about the gain of second stage?
    I have to consider the output resistance of the first stage??? PLEASE HELP
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    I would think the 'logical' thing to do would be to set VD2 [Vo] static bias voltage to 0V or mid-poiint between the ±10 rails. This is an unusual amplifier configuration I've not met before so I would have to look at the circuit more carefully to be convinced in my own mind.
    In any case if VD2 is 0V and ID2 ≈ 7.27mA then RL would be 10V/7.27mA=1376Ω.
    I also think your estimate for ID1 & RE might be off a little.
    One can show for the NMOS
    ID≈(gm)^2/(4*Kn)≈(4E-3)^2/(4*2.4E-3)=1.67mA
    hence
    RE≈0.815/1.67mA=488Ω
  6. Alfa_ET
    Feb 26, 2011
    17
    Why set Vd2 to 0V? maximum excursion of the signal?
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    That was my reasoning - yes. But as I noted earlier I'd have to take a closer look at the large signal conditions to confirm that supposition.
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    Did a simulation of the configuration out of interest.
    I note that the onset of large signal output cut-off is fairly insensitive to the DC bias operating point of the PMOS drain.
    The output THD is ~10% with an input of 400mV p-p.
    Peak voltage gain is about 6x with phase inversion.
    Alfa_ET likes this.
  9. Alfa_ET
    Feb 26, 2011
    17
    Good work.
    RL and RD had given the same value, except RE.
    What simulation software do you use?
    can you check the output resistance of the amplifier? I think the value is close to the value of RL.
    the gain is gm1*RL but i don't know explain why.
    thank you
  10. t_n_k
    Mar 6, 2009
    5,448
    783
    Yes I would think Rout≈RL. The PMOS effectively acts as a current source driver into the load, so looking back into the drain terminal one sees a high AC impedance. That leaves just RL in parallel with a high impedance.
    As to the overall voltage gain I think it would be given by
    A_v=-\frac{g_{m1}g_{m2}R_LR_D}{1+g_{m2}R_D}
    which can be approximated by
    A_v=-g_{m1}R_L
    provided
    g_{m2}R_D>>1
    The latter is true in my simulation setup as the apparent gm2 value is much greater than the value of 5mA/V stated in the original problem definition. That's dictated by the PMOS type and its parameters.
    Looking at circuit values in my simulation the gm1 value works out around 4.3mA/V and this equates well with the observed voltage gain of 6x. Since |Av|≈gm1*RL=4.3*1.4=6.0
