Help: Ac millivoltmeter
Discussion in 'General Electronics Chat' started by hamopp, Mar 21, 2013.
  1. hamopp
    Thread Starter Active Member
    May 13, 2009
    68
    Hi all
    I have an older Leader LMV-181A AC Millivoltmeter, i wanted to know if
    it can be used with an RF Probe, to read rf voltages (i don't think so) as
    the output from the rf probe is dc.
    Can some form of bridge rectifier be used to overcome\convert the volt
    meter so that it reads a dc voltage ??
    Regards
    hamopp
  2. Dodgydave
    Jun 22, 2012
    5,136
    767
    Yes it will work input the signal into the pl59 socket as long as the frequency is under 1Mhz.
  3. hamopp
    May 13, 2009
    68
    Hi Dodgy
    Thanks for that reply.
    Why frequency is under 1Mhz ?.
    I thought that the rf probe, takes the rf voltage at whatever the frequency
    that the diode in the probe works at, and gives out a dc voltage to drive a
    dc millivolt meter. I don't think that it is frequency dependent, it's just a dc
    voltage, is it ?
    Regards
    Hamopp
