help about up/down counter
jrdine
Joined Jul 30, 2013
can you help create a 0-99 counter with up when i pressed button the relay is on , down and reset button and a start button and also once the start button is pressed it will countdown until it reach 00 the relay is off... i need to use pic16f84a....
donpetru
Joined Nov 14, 2008
185
I'd help you, only if you opt for an Atmel microcontroller. Display you want to be with 7-segment or LCD?
The project can be achieved by a small donation to my website (for more details, send me one message).
tshuck
Joined Oct 18, 2012
3,534
Is this because it is for school?
What have you done thus far? Your description is not entirely clear, what does pressing up/down do differently, aside from just counting in a different direction? Does the relay stay on while counting up?
Define what happens on each button press. Draw an ASM chart, it will help you. From there, it's just a matter of coding
your design to match the program flow...
