I have this problem on relay that it didnt have an output voltage when we energize the coil.I check the continuity of the normally open contacts(it become close now when i apply voltage to the relay coil.I check the pin configuration with the broken relay-its the same.
what is the reason behind why is it that i dont have the voltage output? Is there any way that i can modify the said relay?
thanks
thanks
