hello everyone
I'm learning about the CAN network. I program for PIC18F2580 based on MikroC compiler. but I do not understand about the configuration flags such as:
const char
_CAN_CONFIG_DEFAULT = 0xFF, // 11111111
_CAN_CONFIG_PHSEG2_PRG_BIT = 0x01,
_CAN_CONFIG_PHSEG2_PRG_ON = 0xFF, // XXXXXXX1
_CAN_CONFIG_PHSEG2_PRG_OFF = 0xFE, // XXXXXXX0
_CAN_CONFIG_LINE_FILTER_BIT = 0x02,
_CAN_CONFIG_LINE_FILTER_ON = 0xFF, // XXXXXX1X
_CAN_CONFIG_LINE_FILTER_OFF = 0xFD, // XXXXXX0X
_CAN_CONFIG_SAMPLE_BIT = 0x04,
_CAN_CONFIG_SAMPLE_ONCE = 0xFF, // XXXXX1XX
_CAN_CONFIG_SAMPLE_THRICE = 0xFB, // XXXXX0XX
_CAN_CONFIG_MSG_TYPE_BIT = 0x08,
_CAN_CONFIG_STD_MSG = 0xFF, // XXXX1XXX
_CAN_CONFIG_XTD_MSG = 0xF7, // XXXX0XXX
_CAN_CONFIG_DBL_BUFFER_BIT = 0x10,
_CAN_CONFIG_DBL_BUFFER_ON = 0xFF, // XXX1XXXX
_CAN_CONFIG_DBL_BUFFER_OFF = 0xEF, // XXX0XXXX
_CAN_CONFIG_MSG_BITS = 0x60,
_CAN_CONFIG_ALL_MSG = 0xFF, // X11XXXXX
_CAN_CONFIG_VALID_XTD_MSG = 0xDF, // X10XXXXX
_CAN_CONFIG_VALID_STD_MSG = 0xBF, // X01XXXXX
_CAN_CONFIG_ALL_VALID_MSG = 0x9F; // X00XXXXX
can any one explain mean of the configuration flags,please ?
thank every one
const char
thank every one
