You pass the current through a low-value 'sense resistor' and use the mcu to measure the voltage developed across the resistor.How to measure a non-constant current by mcu.
thank you, but i think that charging current be vary to instant voltage at brigde diodes, so I think it is very difficult to measureYou pass the current through a low-value 'sense resistor' and use the mcu to measure the voltage developed across the resistor.
The diac allows charge to build up on C2 until the diac breaks over, dumping the charge into the triac gate to turn the triac on.
Not really. Use a zero-crossing detector to tell the mcu when the bridge output is zero volts. That gives you a reference point so the mcu can then measure current at a predetermined time relative to the reference.I think it is very difficult to measure
Wow! A PolyPak part number. I haven't seen that in a long time.Hello every body
I m searching a three stage battery charger with triac and have a sesult as picture below
but i dont know how this schematic operate. can every one help me
It is three stages charger. I m sure that. Do you know thatWow! A PolyPak part number. I haven't seen that in a long time.
3-stage? Well, variable charger.
Thank you very much. Can you help me about painting voltage wave at output of diode bigde?. Can you measure charging current. Hepl me please. Sory for my englishI'm guessing you put almost no effort into searching for and studying anything about the what and how that goes into a multistage battery charger system being what you have shown there is not anywhere close to being the correct let alone a reliable workable circuit for a three stage battery charger system.
It would be way easier and far more reliable to do the voltage and current control by phase angle firing one the secondary side with two SCR's in place of either the top two or bottom two of the bridge rectifiers not the primary side with a triac.
By putting everything on the secondary side you don't have with trying to accurately and evenly control the phase angle firing points for each half of the sine wave in order to keep the transformer from going into partial DC saturation and burning up plus all the voltage and current sensing is being done on the lower voltage side so no isolation circuitry is needed either.
To give you an idea of how difficult and complicated it is to do voltage and current regulation of the secondary side by phase angle manipulation of the primary side power feed take a look at how it's done on a basic Constant Voltage mini MIG welder unit and imagine trying to graft a three-stage battery charging control into that.
Lincoln SP-100, page 60.
http://www.manualslib.com/manual/95205/Lincoln-Electric-Sp-100.html?page=60#manual
Do you rally think you could build that and have it work?
Also you have not said one thing about what kind of battery (LIPO, Lead acid, NiCad, NiMH, other?) or what voltage (1 cell or 20+ cells?) how small or big it is (.1 Ah or 1000+ Ah?) either which is also very critical information as to what type and size of circuits and control systems you will need to make it work correctly.
An actual three stage charger circuit for lead acid type batteries. It took me about 1 minute of Google searching for 'Three-stage battery charger circuits" to find.
https://pure.ltu.se/portal/files/39903961/iasj.pdf
18 pages of info schematics on how it's done at the simplest level.
by Jake Hertz
by Aaron Carman
by Duane Benson
by Jake Hertz
