Hi, i'm new to this forum and i need some help to find a specific integrated circuit. Basiclly i've got an RGB LED that is hooked up to an arduino board. the board only have 5 gates and one RGB uses 3 and i need at least 3 RGB LEDs. (buying more arduino boards will be too expensive)
So i need some kind of IC that can switch between several LEDs or sets of LEDs
It needs to have 1 input and then be able to switch between for example 3 outputs (3 different LEDs) Does something like this exists? and purchaseable means?
