Help! A Baffling Bridge ciruit...
Discussion in 'Homework Help' started by Mr-Synapse, Dec 7, 2006.
  1. Mr-Synapse
    Nov 1, 2006
    5
    I have a bridge circuit, it is in the shape of the letter "H." It has a single resistor(1 ohm) between it and the source, 10Cos(10^5 r/s + 30deg.)V. I am tryng to find the voltage drop across a two ohm resistor in the lower right side of the "H", Oh the the H as the following values.
    1 ohm resistor 1 ohm resistor 40uF capacitor
    1 ohm resistor
    40uH coil 2 ohm resistor
    Can someone offer some assistance? I've tried delta to wye conversions
    by increasing the 1 ohm resistor in the middle by to two ohms, but lo, the
    solution does not pan out? Arrrgh???
