help 89C51 microcontroller
Discussion in 'Homework Help' started by engr.fahad, Jan 7, 2010.
Thread Status:
Not open for further replies.
  1. engr.fahad
    Nov 13, 2008
    6
    hello every buddy
    I want to ask you that I am making a Transformers less DC power supply by using this diagram
    the ouput of the circuit is 12 volt..​
    I want to add some thing more in this circuit. ​
    Assume load is veribale so it takes differnt current. Now I want to add a DC Ampere meter on load end via using ATMEL 89c51 microcontroller and 7-segement display..​
    IS it possible???​
    If it is kindly tell me the complete process and coding in Assembly language of μController and each every thing. ​
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Several problems arise. Your link does not work. You wish to make a transformerless power supply. Any such device cannot be made safe to use.
    From our rules:
    The nature of the project makes it unacceptable.
Thread Status:
