Help 8051 assembly code seven segment counter
Discussion in 'Embedded Systems and Microcontrollers' started by moses912, Jun 13, 2010.
  1. moses912
    Jun 13, 2010
    Hello, im using a c8051f330 microcontroller and im multiplexing a 4 digit seven segment display. Its common cathode setup. ok i got my code counting from 0 to 9 but all four digits are counting at the same time. I want to count from 0000 to 9999. I got the the seven segments common cathode and here is the code. Can some one help. Please i dont have the schematics just the code in assembly.
    $NOMOD51
    $include (c8051f330.inc) ; Include register definition file.
    display1 equ P0.0
    display2 equ P0.1
    display3 equ P0.2
    display4 equ P0.3
    ORG 00H ; starting code memory location
    SJMP MAIN ; execute main code
    ORG 1BH ; start cord
    MAIN: ANL PCA0MD, #NOT(040h) ; disable the WDT
    MOV XBR1, #40H ; enable Crossbar
    ORL P1MDOUT, #0FFh ; make port 1 output push-pull
    MOV P1,#00H
    LOOP:
    MOV P1, #0BFH ; count 0 to 9
    ACALL DELAYS
    MOV P1,#86H
    ACALL DELAYS
    MOV P1, #0DBh
    ACALL DELAYS
    MOV P1,#0CFH
    ACALL DELAYS
    MOV P1,#0E6H
    ACALL DELAYS
    MOV P1, #0EDH
    ACALL DELAYS
    MOV P1,#0FDH
    ACALL DELAYS
    MOV P1, #007H
    ACALL DELAYS
    MOV P1,#0FFH
    ACALL DELAYS
    MOV P1, #0EFH
    ACALL DELAYS
    AJMP LOOP
    DELAYS: ;1s DELAY
    MOV R5,#10
    D1:
    CALL DELAY
    DJNZ R5,D1
    RET
    DELAY: ;100ms DELAY
    MOV R7,#200
    D2:
    MOV R6,#100
    D3:
    NOP
    NOP
    NOP
    DJNZ R6,D3
    DJNZ R7,D2
    RET
    END
  2. retched
    Dec 5, 2009
    5,201
    313
    It is probably a problem with the hardware. Can you draw up a schematic?
    Use MSpaint or even a pencil and paper and scan it in or use a camera and take a picture of the drawing.
    I have a feeling you have it wired improperly.
    Are you using a 7seg driver?
  3. moses912
    Jun 13, 2010
    no I'm not using a driver. I don't think its wired wrong because they all turns on its definitely a problem with the code. I got P0 defined as my digit selector but Its not multiplex in the code. I don't know how to do that. I was wondering if someone can help me?
  4. Arm_n_Legs
    Mar 7, 2007
    183
    10
    In multiplexing technique, you need to control the sequence the digits light up by controlling the logic of display 1 to display4. You did not implement this step in your program.
