[HELP] 74ls193 count up and down as BCD
Discussion in 'The Projects Forum' started by FarProd, Feb 9, 2012.
  1. FarProd
    Feb 9, 2012
    10
    I'm having problem designing 74ls193 count up and down as BCD from 00 to 99
    (2 digits)
    Using switch will interchange from up to down...
    Any help out there....
    I'm stuck!!!
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Use a 74LS192 instead.
    FarProd likes this.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    As Wookie said, the 192 is a BCD counter, the 193 is a binary counter.
    FarProd likes this.
  4. FarProd
    Feb 9, 2012
    10
    My goal is to use 74ls193 as counter and design BCD up and down counter from 00 - 99 vice versa (2 digits).
    I figured out how 74ls193 work as BCD counter, but the problem is, when it count down, from 9 - 0.. it doesn't come back to 9.. it stay at 0 all the time.
  5. FarProd
    Feb 9, 2012
    10
    74LS193 as BCD...
    How would I cascaded it to make it 8 bit counter
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You need to add logic so that when the output is zero, and the Down input is clocked, that 9 is loaded into the counter instead of 15 like is happening now; as soon as the count goes to 15, the AND gate loads in all zeroes.
    FarProd likes this.
  7. FarProd
    Feb 9, 2012
    10
    How about cascading those two 74ls193 to count from 00 - 99 vice versa?
    Is this Possible?
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Why don't you get just ONE digit working first?
    Once you have a single digit working, the 2nd will be easy.
    FarProd likes this.
  9. FarProd
    Feb 9, 2012
    10
    Can you help me figuring out? I'm stuck!
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    You could go about this two ways. Draw a truth table that with any number over 9 it stuffs 9 into the preset.
    Sense the binary number 10 (1010) and if the output is a 10 stuff 9 into the preset.
    You say you must use a 74193, is this homework?
  11. FarProd
    Feb 9, 2012
    10
    No, I'm just experimenting.
    I had just watched some videos of this using 74ls193, so i'm curious how they implemented it.
  12. Wendy
    Mar 24, 2008
    20,772
    2,540
    As has been said, the 74192 does it directly.
    Have you tried coming up with the gate logic I described?
  13. FarProd
    Feb 9, 2012
    10
    My only problem in my design is that., when it countdown from 9 and reached 0, after that it resumes to 1010 and detect (1010) that will lead to reset... so the output will be 0.
    I know that 74ls192 would do it directly, but how about 74ls193?
  14. Wendy
    Mar 24, 2008
    20,772
    2,540
    Yes, the outputs will go to zero with reset. If you are counting down however the outputs will go to 1111. If the timer hits this condition you will need to stuff 1010 into the presets, and then toggle them in. I designed such a circuit a long while back. I used two different RC constants to sent a toggle after I sent the clock.
    Interestingly, with that scheme (which I did breadboard, it is tested) the equivalent to 1010 was directly on the preset pins, no gates, just hardwired. Think of it as an alternate reset.
    The reason I had to do it is it was a stadium counter, starting from either 3 or 2 on the countdown, with the standard 0 to 5 on the other digit.
    Do you want to see it? It was rather a kludge, but it worked.
    FarProd likes this.
  15. FarProd
    Feb 9, 2012
    10
    Yes, can you show it to me?
  16. FarProd
    Feb 9, 2012
    10
    This my UNFINISHED work!!!
  17. FarProd
    Feb 9, 2012
    10
    The problem is counting down. from 99-00 continously...
    74ls193 U1 is the 1 digit... and U6 are the 2nd digit
  18. bertus
    Administrator
    Apr 5, 2008
    15,797
    2,384
    The problem is, when counting down, the counter will jump to 15 after it has gone through 0.
    (see timing diagram)
    You must detect the "15" and load a 9 at the monent it occurs.
    I also have attached the complete datasheet.
    Bertus
    FarProd likes this.
  19. Wendy
    Mar 24, 2008
    20,772
    2,540
    Looking at it, you still have open inputs. This is a bad habit, which you really need to work on. Any true digital will be erratic and unpredictable, with the exception of TTL, which always assumes a high.
    When I see this I go no further, as the schematic is incomplete. I suspect I am not the only one.
  20. noblewolf
    Aug 14, 2007
    If you are counting down (9..0): the "borrow" (pin 13) goes low in the transition from 0 to 15. Read this pin and when it goes low put 9 (1001) in the data pins (pins 1,9,10,15) AND set low the pin "load" (pin 11).
    Hope this help.
    FarProd likes this.
