HELP! 48V Sensored BLDC motor controller
Discussion in 'The Projects Forum' started by MrElectric, Oct 14, 2013.
  1. MrElectric
    Sep 21, 2013
    Help. This is my first time to build a sensored bldc motor controller. What considerations should i take when building a bldc motor controller? I used AN957 as a reference for my sensored bldc controller. Please give some feedback and suggestions regarding my circuit below. My dspic33f outputs PWM and passes through the driver circuit then goes to the motor. The hall sensor output now goes to the dspic. I used 2 switches for starting the motor and the other switch for direction and a potentiometer to vary the duty cycle.
      File size:
      64.6 KB
      72
      File size:
      42.5 KB
      103
  2. ronv
    Nov 12, 2008
    3,403
    1,478
    The Ir2110 won't work well for this. You need a driver with a charge pump so you can run the motor at all speeds.
  3. Experimentonomen
    Member
    Feb 16, 2011
    331
    46
    It will work perfectly fine! I have used this type of gate drive in motor drives and it has worked perfectly fine.
