Help 48V 12Ah Lead Axit Battery Charger Circuit
Discussion in 'The Projects Forum' started by dknovo, Dec 17, 2014.
  1. dknovo
    Sep 8, 2014
    8
    Hi everyone,
    I'm designing a 48v lead battery charge circuit. However, I found a charger diagram designed for 24V lead axit battery, so can you help me modify the 24V battery charger circuit ( the components' value such as: R, C, Q ...) so that I apply the charger diagram for charging 48V lead axit battery.
    Thanks you so much!
    Here is my 24V charge diagram designed
  2. Alec_t
    Sep 17, 2013
    5,980
    1,138
    That circuit is a 12V battery charger. Have you posted the right one?
    What is the manufacturer's recommended charge current for your battery?
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    Converting that 12V charger to 48V would be just like starting from scratch. Most of the components will not stand operating on ~50V.
  4. dknovo
    Sep 8, 2014
    8
    Thanks for your help!, I don't know how to design a 48V lead axit battery charger circuit. How I should do now ?, or Can you share me a 48V lead axit battery charger circuit.
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    How many Amp Hours per Lead Acid battery?
  6. #12
    Nov 30, 2010
    16,705
    7,358
    12AH, if we are to believe the title of the thread.
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I didn't know there was such a thing as a 48 V Lead Acid battery. But as others have said you will need entirely different components. Do they make datasheets for such batteries? I'd like to see one. That would be my starting point for a new design. Tell us how much you want to spend on developing this charger.
  8. MikeML
    Oct 2, 2009
    5,451
    1,066
    So next questions for the TS:
    How fast do you want to recharge the battery?
    What is the power source? Voltage? Line frequency?
  9. Dodgydave
    Jun 22, 2012
    5,172
    778
