help!! 2 questions on transfer function
Discussion in 'Homework Help' started by killerdevil, Oct 24, 2011.
  1. killerdevil
    Oct 24, 2011
    6
    i am still a beginner and learning and apparently this 2 circuit diagram might be a little to much for me to handle... can someone plz help me?
    Find the transfer function H(s):
    weak at ops-amp... sorry..
    this qn circuit seems a little complicated. i do not know what to do with the dependent source.
  2. crutschow
    Mar 14, 2008
    13,505
    3,376
    They are the same filter circuit except that in the first, the op amp is assumed to have infinite gain (a perfect voltage follower), and in the second, the amp has a finite gain of μ.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    As crutschow has indicated, the two equations are based on the same filter topology as are the two diagrams. If you simply set μ = 1 in the second equation and then simplify the expression, it will yield the same final equation as the first.
    hgmjr
  4. killerdevil
    Oct 24, 2011
    6
    pardon my poor circuit analysis skill, but I don't get what you mean.
