[help] 1n4148 for 16kHz switching frequency
Discussion in 'General Electronics Chat' started by etiquoe, Nov 2, 2010.
  1. etiquoe
    Jul 11, 2010
    27
    hi....
    i'm using 1n4148 for bootstrap diode. i am going to use 16 kHz PWM signal. is 1n4148 an apropriate choice for 16 kHz switching frequency?
    regards
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    16kHz is probably fine - but what about the rest of the diode ratings? Are they likely to be exceeded? What's the circuit look like?
    etiquoe likes this.
  3. etiquoe
    Jul 11, 2010
    27
    the Vcc is 15V, and the current is less than 1A
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    How much less than 1A?
  5. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    A 1N5819 might work. What's it for?
    etiquoe likes this.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    1N4148 diodes are suitable for up to around 100mA continuous current. The absolute maximum peak rating is 1A for 1 second , but Vf then exceeds 1v.
    You'd probably be better off using something like a BAT42, BAT43, 1N5817 thru 1N5819 - basically, a Schottky diode with a reverse voltage rating higher than you expect it to see.
    Ultrafast switching diodes can also be used, but they will have a higher Vf than Schottky types.
    etiquoe likes this.
  7. etiquoe
    Jul 11, 2010
    27
    it's about 2 mA
  8. etiquoe
    Jul 11, 2010
    27
    it's for bootstrap diode in MGD circuit for bldc driver bridge
