Help: 12V, 12amp DC motor Linear Actuator Direction Control
Discussion in 'The Projects Forum' started by pranil.maniyar, Mar 14, 2013.
  1. pranil.maniyar
    Nov 20, 2012
    I am new-bie here. I was searching solution for my problem on google, I came across with this site.
    I am using 12V, 12 amp DC Motor Linear Actuator. I want to control it's direction. right now I am using heavy Duty DPDT Relay. It worked fine. next I used TO3 type NPN-PNP Trasistor (2 x MJ15025 PNP & 2 x MJ15024 NPN) H Bridge Circuit, 12V x 12 amp = 144W , as My wattage is high so I am getting heat in those transistor. but Its not as successful as Relay.
    so I am looking for a circuit.
    I have a brake foot-pedal switch of Tractor, when it foot-pedal is pressed on signal(current) comes in 7 plug socket. I am using that signal as input to my Relay. Its working fine. but I want to make Electronic Circuit for that.
    My Signals is mainly through that foot-pedal switch. ON & OFF. the Actuator's motion should be FORWARD when Foot-Pedal is Pressed, When foot-pedal is released the actuator should be REVERSE. the time for this operation is not fixed & if foot-pedal is pressed, linear actuator is in forward direction & ignition switch turned to off it remains in engage(extended) postion.
    Can you tell me how can I do that?
