someonesdad
- Joined Jul 7, 2009
- 1,583
How about a description of who and what the project is for? Of course, you could have mentioned it earlier, but I'm too lazy to go back and search (as in "I've fallen and I cannot get up!").
Well, I guess we'll see if the turn on surges pop the fuse or not. In retrospect it was a silly thing to ask you to do. A perfect transformer would have no DC resistance at all but of course, they don't exist.I measured resistance between the two wall-plug-side terminals on the transformer with nothing plugged in. I get 12.0 to 12.1 ohms.
I have to say that I was smiling while viewing your pix. Especially, the carpeted floor in your wood shop!Here's the dial side of the control box.
Also, imagine all of this is varnished or something. It will be prettier some day.
Are they getting hot? If you poke at them does the meter jump around. I came into this thread a bit late. Someone else (I believe) helped you out with calculating their values and wattage. I just assumed that part of the project was worked out. Check for a cold solder joint... that's what the poking was for.Funny. My 4700 and 47 ohm resistor arrays and no resistors give nice, stable magnetic field outputs. 150 ohm resistor array fluctuates with an amplitude of around 2 milliGauss. Any thoughts as to why that would be?
My question too, t_n_k, after seeing the pictures. IIRC, the separation of the coils (either round or square) for Helmholtz coils is proportional to their radius. If you're interested, I have a copy of Grover's book on inductance calculations somewhere and I could look the stuff up for you. Or, it can probably be found on the web somewhere; I'm too lazy to look.Only one comment - is this a true Helmholtz coil?
