Here's a method of dealing with rotary switches that make contact with two poles for each switch position.
This is weird. I would swear that this post didn't exist when I posted the rotary switch schematic. I wouldn't have bothered.I unsoldered my gear and tested it yesterday to confirm that the switch only selects one position at a time. I was doing my continuity tests in the wrong location, it turns out. After I re-brained myself, I could see what I did wrong.
Voltmeters are always connected across the source or the load. Ammeters are always connected in series with the source or load.Questions:
1) Should I install the voltmeter in series or parallel? (I'm thinking it needs to be parallel).
2) Does it matter if the wall plug for the transformer is polarized?
3) Given the above answers, does it matter where the fuse is located?
As I indicated on the schematic (Notes) ... No.Oooh! Thanks! Of course, I now have more
questions for you.
Now, the plug that I have has no large pin on it. They are both the same size.
From your description RE: the insulated case, this shouldn't be an issue?
I doubt very, very much that your fuse is rated at .315 Amps. That wouldThe fuse is .315 A. I've been using it on the 12 V side of the transformer.
I presume this will still be okay if it's located on the mains side of the
transformer? If not, please explain why and suggest a proper fuse
(would it be 3A if my transformer is rated for 3A?).
No, your fuse value is based on max current.I'm also running on 12 Volt, which I presume doesn't matter.
If it's rated for 120VAC then you can use it as the Power switch indicatedAND I have a little 2-pole rocker switch/power switch that I forgot to
mention that I will put in the circuit as well (ugh--too many parts). Does
it matter where that goes?
Yes, they were put there and labeled to show proper hookup.I have no ammeter, just a volt meter. I understand they serve similar functions.
Is your diagram intended to show the difference between how a voltmeter and an ammeter would fit into the circuit? If not, do I need an ammeter and why?
Your pdf schematic shows R4 in series and that's why I drew it that way.R4 as I had it in my diagram is a lamp. If I install it in series, it will disable the
circuit if it burns out. Is there any reason not to keep it in parallel like I had it?
