I am building a square, single-frame Helmholtz coil device for tracking the drift of an EMF meter between calibrations. I need some help figuring out resistors for controlling the circuit so that I can get 3 different magnetic field outputs in the center of the coil. Keep in mind, I'm not trying to calibrate the meter, I just want to qualitatively track whether it is losing calibration over the course of a year.
The coil gizmo I've built is self-contained and portable. The coil lives in the bottom of a large, flat wooden box. The controls live on the lid of the box, and I have designed the lid, complete with controls, to be separated from the coil so that they do not interfere with the magnetic field (within reason).
I have the following components:
- A square coil wrapped around a wood frame that is 18 inches long per side, consisting of 9 turns of a single strand of (approx.)16 gauge speaker wire (so, about 72 linear feet of wire)
- I twisted together the two wire tails that come off the coil (to control induction), and these two lead wires will attach to the transformer circuit
- The control box is driven by a 3 A transformer (AC) with a 12 or 24 V output and a polarized plug
- A 3 Amp fuse will be installed between the transformer and the coil
- On the other side of the coil, a 3-way switch will be installed to select one of 3 resistors that will help control the strength of the magnetic field
- A 1 Amp voltmeter will be installed (after the 3-way switch) on either end of yet another resistor to monitor voltage
Today, I hooked up the power cord to the transformer, and hooked the coil wires directly to the output on the transformer (I used 24 V output). I set my EMF meter in the middle of the coil, donned safety glasses, grabbed a fire extinguisher, and switched the circuit on. I achieved a magnetic field in the middle of the coil of approximately 3200 milligauss . I switched everything off before the smoke escaped. I call that a success.
I tried it again with the 12 V output and got about 3000 milligauss. Not much of a difference.
Now I'm stuck. I am having a hell of a time with the math for calculating the resistors I need to get the magnetic field outputs I want. Math has never been my strong point, and I am completely befuddled by the Helmholtz formula. So, I am hoping someone here can help me figure out what resistors I'll need to get the approximate magnetic field I want.
What I'm hoping to achieve, using resistors connected to the 3-way switch, is the following output:
- 1 setting of approximately 10 milligauss
- 1 setting of approximately 200 milligauss
- 1 setting of approximately 500 milligauss
By "approximately", I mean within 50 to 100 milligauss.
FINALLY, The Questions:
I understand that my power output using 12 V transformer setup is 36 Watts, and that it's 72 Watts as a 24 V transformer. How in the heck do I calculate what resistors I need?
I know there's a 4th resistor in the circuit for the voltmeter that needs to be factored in (I have the formula RL = Rs +Rn where RL = all resistors together, and Rs = the sensor (voltmeter) resistor, and Rn = whichever resistor is selected with the 3-way switch).
In addition, I'm pretty sure these are huge power resistors, and I'd like them to be within +/- 2% accurate --what's a good source for these things?
Any kind of specific suggestions you folks can offer along with reference formulae would be appreciated. I really just need to get this monster built.
Thanks!
Maxine
Thanks!
Maxine
