Held held computer???
Discussion in 'The Projects Forum' started by thenovice, May 9, 2007.
  1. thenovice
    May 9, 2007
    I have absolutely no electronics knowledge at all, so really I'm asking if this is possible within a reasonable budget. I want to build a hand held device with a screen (mobile phone size) that can display simple text files, has a usb port, so I can connect a pen drive to store the text files, and a 9 pin RS232 port to transfer the files with certain protocols.
    Firstly is this possible to build myself? Do I need some sort of processor or can I use flash memory to control the configuration settings? Idea's on costs? Thanks for reading.
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    You will need to learn about microprocessors, USB and RS232 protocols, and programming. All memory does is store what you put in it.
    I'll take a wild guess at seventy bucks, USD.
  3. Tube Tech
    Jan 11, 2007
    46
    You're trying to invent the Palm Pilot?
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    I don't think they are. They said nothing of text entry, only text display. Sounds more like book-reading tool, except a reader would need a bigger screen. (At least it would if I were the one using it...:p)
  5. thenovice
    May 9, 2007
    In theory then I could take something like a palm pilot remove the bits I require, eg processor and programming is done for me? Then add my own screen and ports etc?
    I am trying to devise a device to transfer text file from a pc tgo a mchine for programming purposes, there are many devises out there but all are over speced and over price looking for a simple low cost alternative.
