Heavy duty PWM DC motor controller help
Discussion in 'The Projects Forum' started by eggplantparrot, Mar 25, 2015.
  1. eggplantparrot
    Mar 25, 2015
    43
    hello, I have salvaged a big 2 HP treadmill motor and have built a disc sander with it, but the treadmill controller stopped working during testing, and now I need a motor controller preferably PWM.
    if anyone can help me create a list of components to driver such a big motor it would be greatly appreciated.
    the motor is rated for about 105V DC at 18A I have salvaged a bridge rectifier from the treadmill driver and it works in converting AC to DC. I need a simple circuit, variable speed to start the motor at low speed, and can handle at least 15 A since the motor would be started at low speed and slowly turned up, and would never be run at full throttle. I can solder with no problems, but I have no knowledge of specific electronics like PWM chips. a list of parts and a simple diagram would be very helpful.
  2. eggplantparrot
    Mar 25, 2015
    43
    would a simple 555 timer controller work with the output on a big MOSFET and the MOSFET connected between rectifier and motor?
  3. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
  4. eggplantparrot
    Mar 25, 2015
    43
    thx for reply. I see that the 555 timer input voltage is 6VDC and the output is also 6VDC, but the voltage I measured from my rectifier is ~100VDC (I don't remember exact number) that means I would have to step it down for the timer right? also the ground on the MOSFET in the diagram is a common ground with the rest of the electronics, but as before, my MOSFET would be receiving ~100VDC and then sending it to motor, I wouldn't be able to ground it with the timer then?
  5. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    The low voltage common and high voltage DC common can be connected.
    The low voltage could be sourced from a Wall Wart supply etc.
    Max.
  6. eggplantparrot
    Mar 25, 2015
    43
  7. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    You might go with a IRL540 100v @ 28A.
    Max.
  8. eggplantparrot
    Mar 25, 2015
    43
    dam I was hoping to reuse the ones I have, they had heat sinks too, any reason I shouldn't use them? I mean they were from the treadmill controller anyways, rated for way more than I need at 200V and 33A? I mean I will get the ones u suggested but I would prefer to use whatever I already have since it was all free lol
  9. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    You would need to check the gate requirements and modify the LV supply voltage to suit.
    Max.
  10. eggplantparrot
    Mar 25, 2015
    43
    oh, you mean like the IRL540 VGS is 5V but on the IRFP250 its 20VGS? im guessing the output on a 555 is the same as the input so if I were to use a 5v wall wart to power the 555 then the output of the 555 would be 5v, and that would be good for the IRL540 and not high enough for IRFP?
  11. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    Yes, the maximum supply for a 555 is 15v IIRC so you could design for this value to use the IRFP250.
    Max.
  12. eggplantparrot
    Mar 25, 2015
    43
    Wait, so it's ok if I use lower voltage supply for the 555? I have a bunch of 12v charger warts that I can use, what would happen if I use those? Since the IRFP calls for 20V what would happen? To be honest I think I would probably use the one you suggested for simplicity
  13. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
  14. eggplantparrot
    Mar 25, 2015
    43
    2005-10a-004.gif 2005-10a-004 ver2.gif so if I were to use this circuit and the IRL540 how would I connect everything up? I modified the first pic to what I think I'd hook up, but I feel like im missing some connections, particularly with grounding them.
  15. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    The first would be more appropriate.
    Max.
  16. eggplantparrot
    Mar 25, 2015
    43
    but the first one doesn't use an outside source of power for the motor, its the same supply as the 555 input power
  17. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    Use whatever suitable separate supply that will work for the motor and a separate one for the 18v and just connect the commons.
    The cheap ones you buy on ebay use a single high voltage DC motor supply and a simple zener to supply the 555 circuit.
    Max.
  18. eggplantparrot
    Mar 25, 2015
    43
    then I connect the negative end from the rectifier with the ground of the pwm circuit?
  19. BillB3857
    Feb 28, 2009
    2,402
    348
    PLEASE - show an isolation transformer before your bridge. Otherwise, you violate the terms of service as well as create a hazardous condition.
  20. eggplantparrot
    Mar 25, 2015
    43
