Heavy Duty Inverter
Discussion in 'General Electronics Chat' started by high voltage, Oct 25, 2007.
  1. high voltage
    Oct 25, 2007
    I,am trying to build a transistorized power inverter with transistors that have a maximum ic current of 300 amps, what type of power output can I expect and also what considerations do I have make when building this project?
  2. cumesoftware
    Apr 27, 2007
    1,330
    11
    Expect an efficiency from 50% to 75%. Given the input power, you can figure the output power. But the efficiency pretty much depends on the circuit and components you are using.
  3. Murod
    Dec 24, 2005
    30
    I've search for high-current rated power MOSFET, but no luck so far. How about the idea to make many parallel coils with many independent driver for each coil to minimize the skin effect? I think you can easily find power mosfet rated for 50A+ and you can use 6 driven coil sets.
    Btw, do you wan square, modified sine, or true sine output? Just curious if you wanna share. :)
