Heatsink calculation
Discussion in 'General Electronics Chat' started by Rooskey, Mar 31, 2014.
  1. Rooskey
    Oct 18, 2011
    Hi, I am using a lm317 voltage regulator to power a pump.Vin to the regulator is 15V, Vout =11V.Current to the pump =2A.
    So I take it that power dissipated = (15-11)*2 = 8W
    Tmax = 60, Tamb = 20, so the max thermal resistance of the heatsink would be (60-20)/8W =5 degrees C/W.
    How do I size a suitable heatsink from this?
    Thanks,
    M
  2. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Personally, I'd check the manufacturers' datasheets for advertised heatsinks and see what sizes/formats have the required thermal resistance or better.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    Is not the max current for LM317 at the best 1.5A and less in some cases depending on package type. Most often electric motors have a broad voltage range. Are you sure you need a regulator at all. What kind of pump are you using any link or datasheet?
  4. Rooskey
    Oct 18, 2011
    I am controlling a diaphragm pump between 6 and 11V and when it runs at 11V it take approx 2 Amps.From the datasheet the LM317 has a max of 1.5 (Iwas looking at the typical Io =2.2A.Thanks,
    http://www.fairchildsemi.com/ds/LM/LM317.pdf
  5. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Be aware at startup the pump current draw is probably a lot more than 2A. The LM317 will be stressed even at 2A and should have an auxiliary transistor to pass the extra current.
  6. Jony130
    Feb 17, 2009
    3,991
    1,116
    In LM317 datasheet we can find Rthjc = 5°C/W for TO220 case and Tjmax = 125°C
    http://www.st.com/web/en/resource/technical/document/datasheet/CD00000455.pdf
    The power dissipated in your circuit is equal to 8W.
    So RTh = (120 - 20)/8W = 12.5°C/W.
    So you need a heatsink with Rth < 12.5 - 5 = 7.5°C/W
    For example this will do the job
    http://assmann.us/specs/ASS_0867_HSrev03(V7477xC).pdf
    And you can pick heatsink here
    http://www.digikey.com/product-sear...t=0&page=1&quantity=0&ptm=0&fid=0&pageSize=25
    http://pl.mouser.com/Thermal-Management/Heat-Sinks/_/N-5gg0?P=1yzxb21
  7. Rooskey
    Oct 18, 2011
    Thanks a million for that,really appreciate it,M
