heating element in rework station
Discussion in 'General Electronics Chat' started by johndoe45, Aug 18, 2011.
  1. johndoe45
    Jan 30, 2010
    364
    i have a heat gun which glows at 750°F and really bright at 1000°F.
    now the aoyue 968 heat gun does not stay glowing. it fades in and out at 400°C. is this right? or is the heating element bad. making a video.
  2. johndoe45
    Jan 30, 2010
    364
    here is the video of the aoyue 968 hot air
    i'm not sure if it is supposed to glow fading in and out. thought it was supposed to be constant
    http://www.megavideo.com/?v=YY1LB7QH
  3. tom66
    May 9, 2009
    2,613
    214
    That's completely normal. It is regulating the air temperature. To do that it blows air over the element which heats up slowly. The element glows when hot and when the air reaches the right temperature it decreases the temperature of the element and then increases it and then decreases it... and so on... to regulate the temperature. Mine does the same.
  4. johndoe45
    Jan 30, 2010
    364
    ok cool. thanks for the quick reply.
    cause the heat gun just stays glowing from home depot. but probably not the same thing. so was just wondering
  5. tom66
    May 9, 2009
    2,613
    214
    Probably because it's not temperature regulated. It just says "half power" and it hopes that is a certain temperature.
