Hey Fellows,
I'm fixing up an old Heathkit IP-27 power supply for a friend because it isn't working properly. At first It wasn't working at all, but when I took out the fuse and put it back in, it started working again (but not to its full potential). So It was a little dirty and needed some cleaning. Apparently, when you have a load you shouldn't get any voltage drop and the power supply will compensate for the loss voltage. So the voltage stays the same no matter the load. Unfortunately, this isn't happening and when I put a 100Ω resistor around 5V or so the voltage dropped significantly. My first guess is replacing the electrolytic caps since those don't last very long; but I might be wrong. How can I fix this? Here is the schematic because I couldn't find the whole manual online:
http://www.nostalgickitscentral.com/heath/schematics/heathkit_schema_ip27.gif
I'd appreciate the help!
