Heathkit GC-1005 Clock Manual
Discussion in 'Electronics Resources' started by sfeinsmith, Jul 14, 2013.
  1. sfeinsmith
    Mar 20, 2013
    16
    I downloaded PDF from varies websites and discovered all of them were incomplete copied. Someone only copied except assembly procedure pages. I have to overhaul Heathkit GC-1005 clock because someone built it in very poor job and I have to pull all "color coded ribbon cable" as I discovered some of them soldered at wrong ports. I need a complete manual to show actual length of cable to cut and stripped properly.
    Any of you may have discard front "smoke" plastic cover for GC-1005 as mine was missed. It will be nice to restore the clock and run years ahead. This device will replace my long time lost original GC-1005 that was stolen almost 13 years ago when I moved from South Florida to Virginia.
    Thank you,
    Steven
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  3. sfeinsmith
    Mar 20, 2013
    16
    Thank you for information but it was same one as I downloaded previously. There were missing pages number 5 to 20 contained assembly procedure. That section that I need to create new colored ribbon cable into proper length.
    Hopefully, you may capable to find it somewhere as so far I have not find a complete GC-1005 manual.
    Thanks,
    Steven
  4. ruygrap1
    Jun 27, 2014
    I have the complete manual of the GC-1005, build in 1973 and still working, only the MK5017AA was replaced several times, last in 2000.
    Are your pages 5 to 20 still missing?
    Ap
