heater help
Discussion in 'General Electronics Chat' started by nitko12, Oct 18, 2015.
  1. nitko12
    Oct 14, 2015
    12
    I need something like electrical tape that doesnt conduct electricity but conducts heat very well (around 200-250 celcious)
    Does something like that even exists ?
  2. RichardO
    May 4, 2013
    1,336
    429
    Polyimide (also called Kapton ) may work. It will withstand the tempeature but I don't know how thermally conductive it is.
  3. GopherT
    Nov 23, 2012
    6,304
    4,029
    No. As soon as you have any thermal conductor formed into a thin tape, it becomes an excellent shape to dissipate the heat out to the surroundings.
    There are other thermal tapes (Aka heat tapes) that are essentially resistance wire in an insulating sleeve. You can wrap the tape around what you need heated and then plug it in.
  4. Brownout
    Jan 10, 2012
    2,375
    998
    I thought that's what he wanted.
  5. WBahn
    Mar 31, 2012
    18,085
    4,917
    What direction do you need the good thermal conduction to go in? From one side of the tape to the other, from one edge of the tape to the other, or down the length of the tape?
  6. nitko12
    Oct 14, 2015
    12
    It needs to conduct heat from resistance wire to metal cube but if i just wrap it around it would make a short circuit so I need to insulate the wire from metal by some tape so it would be heat dissipation from one side to another :)
  7. GopherT
    Nov 23, 2012
    6,304
    4,029
    Depending on the temp you need, you can use Kapton tape (thin and fairly high temp, or, if high temp is needed, you can use ceramic thin sheets (.1 mm) made of mica, boron nitride, etc. for lower temp, you can use - nomex or kevlar cloth (fire resistant).
  8. GS3
    Sep 21, 2007
    408
    35
    Google *heat resistant wire sleeve* and you will get plenty of hits.
  9. nitko12
    Oct 14, 2015
    12
    I think Kapton (Capton) will do
  10. nitko12
    Oct 14, 2015
    12
    Thanks for your replys :)
  11. Brownout
    Jan 10, 2012
    2,375
    998
    Wrap your object with the kapton, and not the wire.
