Heated jacket or liner project
Discussion in 'The Projects Forum' started by Jiggygent, Jan 3, 2013.
  1. Jiggygent
    Jan 3, 2013
    Ive researched a bit on this type of project, but most of the stuff I find is in regards to motorcyclists who connect their jackets to their vehicles batteries. I was thinking of dosowing similar jacket design with a small portable battery source (maybe a 7.4v lipo battery), but can't seem to find much regarding the best parts to put this together. I figured I'd use some .30 AWG Teflon coated wire as the heating element. Its been a while since I've tried anything like this, so forgive me if this is something I am overlooking.. I am a novice. I want to be able to adjust the output for the heat, but can't seem to find an appropriate voltage regulator. If anyone can point me in the right direction tha would be great.
    So far, my parts list is:
    On/off switch
    Voltage regulator to control temp.
    If there is any ideas on how to improve this, or if I'm missing something, p,ease let me know. I appreciate any assistance.
  2. crutschow
    Mar 14, 2008
    13,518
    3,386
  3. wayneh
    Sep 9, 2010
    12,403
    3,252
    You need to think about how much power the heating element uses versus battery capacity. A "small" battery might not last long.
    Take the PWM advice and forget the voltage regulator - it's not a good choice for this. It might be overkill to include a thermostat, but you could easily do so by putting the PWM under control of an LM35 thermometer IC. This may all sound too complex, but it's not as bad as it might sound.
