1. Jaguarjoe
    Thread Starter Active Member
    Apr 7, 2010
    770
    90
    The attached pdf is the circuit for the ignition system in millions of GM cars and also my Jaguar. It commonly known as a 4 pin HEI module and looks like this:
    http://tinyurl.com/2bjxqwx
    It limits the charging current to the ignition coil to about 5 amps. The driver darlington MJ10012 has a Vce(sat) of 2 volts. When the darlington conducts, it has 5 amps flowing through it and a 2 volt drop across it. That's 10 watts of heat to dissipate. I realize that is not an insignificant amount of power, but why does this thing run so hot you can't put your fingers on it?
  2. mik3
    Feb 4, 2008
    4,846
    63
    It should be mounted on a heatsink. If it is designed to work without a heatsink then something is wrong.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    I agree with mik3. A heatsink is need to increase the heat dissipation out of the device.
    hgmjr
  4. Jaguarjoe
    Apr 7, 2010
    770
    90
    On GM products it is mounted to a substantial aluminum piece. On the Jag its mounted in a small box attached to the inlet manifold through two standoffs.
  5. DigitalReaper
    Member
    Aug 7, 2010
    70
    You can actually see a tube labeled silicone in the picture which is probably thermal paste (used for mounting it on a heatsink). Do you have the module securely bolted on to where it's supposed to be mounted and did you use the paste? It uses whatever it's mounted on to dissapate heat.
  6. mik3
    Feb 4, 2008
    4,846
    63
    It seems that GM has done a better job than Jag!
  7. Jaguarjoe
    Apr 7, 2010
    770
    90
    Silicone isn't a good thermal conductor. I use berylium oxide heatsink paste.
    I remounted the module off to the side of the car away from the engine heat and covered the top of it with a heatsink. It still gets hot as a pistol.
    How much heat does 10 watts generate?
    No doubt GM did a better job with this than Jaguar did. This car was built before Ford took them over and re-invented them. In the pre-Ford years anyone did a better job than Jaguar and Joe Lucas.
  8. marshallf3
    Jul 26, 2010
    2,358
    201
    10W is more than you think but I don't recall those old modules ever getting that hot. You might have an ignition coil drawing too much power due to a shorted turn.
    Chrysler used a similar device, they actually mounted it in the air cleaner housing so some air would blow over it.
  9. retched
    Dec 5, 2009
    5,201
    313
    I would have to agree with the shorted winding..
    You should really probe this and get the actual amp draw.
  10. Jaguarjoe
    Apr 7, 2010
    770
    90
    Over the years, I've had three different ignition coils in this car and there was no noticeable difference in temperature. Being current limited to 5 amps, what difference would a bad coil make anyway?
    A few years ago I used a 0.1 ohm shunt resistor to see the module work on my scope. You could see the coil charge up and then sit at 5 amps just like it should.
  11. marshallf3
    Jul 26, 2010
    2,358
    201
    Old technology. With only four pins it couldn't be that complex of a circuit, why not make one up using a modern MOSFET?
  12. retched
    Dec 5, 2009
    5,201
    313
    Im thinking that the current limiting process or circuit is, or may be dead/dying.
    I would like to see numbers on a ammeter.
    Unless you have 'super sensitive' fingers, this device should not be "HOT" hot to the touch.
    I dunno... have you had a look at the motorcycle AC regulator thread? It has 1 wire and it contains QUITE a smathering of components that has taken weeks to put together.
    Is "smathering" a word?
  13. Jaguarjoe
    Apr 7, 2010
    770
    90
    I found this mosfet in about 5 minutes which would almost work:
    http://www.fairchildsemi.com/ds/FC/FCPF13N60NT.pdf
    I'd need a good gate driver but worst of all, the MC3334 IC which is the brains of this whole thing is no longer available :(
    Years ago Silicon Chip magazine had an article on building one of these. I don't recall if it was BJT or FET equipped. I think it used the same IC.
  14. marshallf3
    Jul 26, 2010
    2,358
    201
    You can still buy things that will subsistute but I'll almost bet you the circuit's out there somewhere. If I recall there's just a hall efect or simple electromagnetic sensor in the distributor that operates some simple switchable biasing on the coil driver transistor.
    So you haven't even tested or replaced the thing? Most any auto store will test those for free, I even have a tester for the common ones here at home.
    You can do a lot better than that MOSFET both in amperage capability and Rdss_on for about the same price.
    Try something like this:
    http://www.mouser.com/ProductDetail...GAEpiMZZMtCrm2fS1SYQuPoGNV9k5Et%2b3UvskdTnnw=
  15. Jaguarjoe
    Apr 7, 2010
    770
    90
    I've been through numerous modules. Many run for 20 minutes and die. Others do better. At only $15 each, I kept looking for a cool one, but they're pretty much all alike.
    I looked at that mosfet you found. Its only good for 30 volts. I need 375- 600. As voltage goes up, so does Rds on. I end up with just about the same drop across it as the darlington has.
  16. marshallf3
    Jul 26, 2010
    2,358
    201
    Unless there's an integral CDI hidden in the box or elsewhere you're just seeing the back EMF from the coil when the current source to it is broken. That's what a good rectifier reverse connected across the coil primary is for.
  17. Jaguarjoe
    Apr 7, 2010
    770
    90
    You can't put diodes across ignition coil primaries, it slows them down too much. At 6,000rpm, the coil on my V-12 is zipping along at 600Hz. The MJ10012 in there now is good for 375 volts. There is a 350 volt zener across it to protect it from the coil back emf.
