heat sink part number identification
Discussion in 'General Electronics Chat' started by ak52, Jun 7, 2015.
  1. ak52
    Oct 15, 2014
    145
  2. shteii01
    Feb 19, 2010
    3,505
    512
    I see 5 FETs (Field Effect Transistor) attached to a heat sink.
    What I don't see is the part number.
  3. ak52
    Oct 15, 2014
    145
    I am looking for heat sinks like that online but i am not able to find any,is there any standard size or form factor which i could use as a reference?
  4. paulktreg
    Distinguished Member
    Jun 2, 2008
    625
    125
    Make your own?
    Plenty of L section aluminium available, here for example.
  5. ErnieM
    Apr 24, 2011
    7,439
    1,627
    paulktreg has a good point. This is not a purchased heatsink but something the manufacturer made from a standard aluminum extrusion.
    There is no reason it must look like your picture, you may want a different (simpler) shape to move heat from one place to another.
  6. ak52
    Oct 15, 2014
    145
    I see ,thanks guys,i was under the impression it was a standard part.Any aluminum piece would do the trick in this case
  7. AnalogKid
    Aug 1, 2013
    4,699
    1,298
    That probably is a chunk of aluminum angle cut to length and drilled. Lowes, Home Depot, etc. It is an extrusion, not a bent piece. It might be a custom extrusion, but it is not a catalog standard heatsink part. Note the two solderable legs crimped on. This used to be a sign that the part was from a heatsink company, but I've seen CMS shops bring this technique in-house.
    ak
