Heat Sink gets heat up on LM7808
Discussion in 'General Electronics Chat' started by Vindhyachal Takniki, Jan 9, 2016.
  1. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    I have 12V input on LM7805, & output load current is aroung 600-700mA.
    I have connected a large aluminium heat sink with fins on it. Problem is that in 5 minutes of operation heat sink gets too hot, so that i cannot even hold it with hands for more than few seconds.
    Can my circuit works for continuous 1 day for that? or I should go for some dc-dc.
  2. nerdegutta
    Dec 15, 2009
    2,569
    806
    Hi.
    Please upload you schematic diagram, and a picture of your circuit. Did you solder it yourself, or is it on a bread board?
    Is it a 7808 or a 7805?
  3. hp1729
    Nov 23, 2015
    2,105
    235
    LM7805?
    Is dropping 7 Volts at 800 mA. Yep, might get warm. It could also be oscillating, but I suspect you would know that.
  4. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    Its simple LM7805. Output voltage comes around 4.80V when loaded. I have soldered the board myself. Will post schematic also.
  5. Picbuster
    Member
    Dec 2, 2013
    391
    53
  6. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    P=7*.8=5.6Watt
    use big heat sing or low the input voltage if possible.
    yes it heat at high current
  7. R!f@@
    Apr 2, 2009
    8,792
    771
    Did you use decoupling capacitors ?
    Johann likes this.
  8. GopherT
    Nov 23, 2012
    6,322
    4,050
    The 7V drop x 700 mA is 5 watts. That is a big heat sink. It should also get forced air cooling from a fan.
    You could use a DC/DC converter and that will reduce the heat.
    You could also get a different SMPS supply to power your project (e.g. Use a cell phone charger for the 5v source) or any other DC source that is not 12 V
    Finally, you can make sure that your circuit needs 5 V. Some CMOS chips can handle higher, LEDs can be powered with higher if you use appropriately sized current limiting resistors. They way, all the heat is dissipated over more components instead of one poor little 7805.
  9. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    If you want to burn less power in the same footprint, try the muRata OKI-78SR-5 . You may not need a heatsink.
    ScottWang likes this.
  10. R!f@@
    Apr 2, 2009
    8,792
    771
    Where can I buy these. I can use them
  11. ISB123
    May 21, 2014
    1,240
    531
  12. GopherT
    Nov 23, 2012
    6,322
    4,050
  13. dl324
    Distinguished Member
    Mar 30, 2015
    3,384
    653
    Prices at places like Mouser and Digikey are 2-3X that!
  14. dl324
    Mar 30, 2015
    3,384
    653
    Being too hot for you to touch isn't a practical indication of a component being stressed.
    LM7805 will operate at a junction temperature of 125C. Thermal resistance from junction to case is 5C/W, so it won't start temperature throttling until the case is 100C. Unless you're a professional chef, you'll find that temperature too hot to tolerate even briefly; but the part will be within it's specs.
    Johann likes this.
  15. GopherT
    Nov 23, 2012
    6,322
    4,050
    What makes them special? Were they born with fingers made of Nomex?
  16. dl324
    Mar 30, 2015
    3,384
    653
    No. When it comes to handling things that are hot, many of them have conditioned themselves to tolerate a higher level of pain.
    absf, Sinus23 and GopherT like this.
  17. crutschow
    Mar 14, 2008
    13,508
    3,384
    What is the size of this "large" heatsink?
  18. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  19. R!f@@
    Apr 2, 2009
    8,792
    771
    Dang....that is expensive.
    I stick with 7805 and a sink
  20. hp1729
    Nov 23, 2015
    2,105
    235
    That sounds like it is loaded down more than 800 mA.
