Heat Shrink / Desolder
Discussion in 'General Electronics Chat' started by c0de3, Feb 3, 2012.
  1. c0de3
    Thread Starter Active Member
    May 1, 2009
    50
    Hi all,
    I'm new and building up my supply of electronics kit. I'd like to buy a heat gun for doing heat shrink on my projects. However, I also recycle a fair amount of parts from old gear so I'd like to also be able to de-solder with the heat gun. Can I get a single gun to do both tasks, or is it two different guns? Does anyone have a suggestion for a "hobby-class" device? I'd like to stay under or around 75$ if possible.
    Thanks for any tips!
    - C
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    If you are interested in salvaging fine electronics (such as MOSFETs, caps, resistors) you will need the same kind of iron that you would use to build them. Heating a mass of parts tends to damage a lot of the finer components.
    In my opinion this should be in the electronics chat forum. Want me to move it?
  3. c0de3
    May 1, 2009
    50
    Sure, Please move. I wasn't sure it should be electronics chat so I put it here to be safe. Thanks!
    I don't work with much "fine" stuff if you mean fine as in size. Mostly through hole type components. If that helps?
  4. mcgyvr
    Oct 15, 2009
    4,783
    973
    If you bought a hot air rework station you could use the hot air gun to do shrink tubing for sure.. But I wouldn't use a regular hot air gun (typically used for paint removal,etc..) to rework smt parts.
    There are some cheapo hot air rework stations with a soldering iron and hot air gun on ebay for around your price range.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I bought a super cheap heat gun from Harbor Freight for around $10 on sale to use for heat shrink. They are very light duty units. It seemed to work OK for heat shrink. I tried using it for desoldering some SMT components from a scrap board, but it took too long, and the heat gun itself overheated and one of the elements broke. I fixed it, but as I mentioned, these weren't made for anything but casual, intermittent use. Better than using a lighter on the heat shrink though.
  6. spinnaker
    Oct 29, 2009
    5,062
    1,159
    I have had no such issues with my HF gun. The only issue I have is I cannot concentrate the heat at a specific point. I believe they sell a kit with different shaped nozzles. I've looked for it but was never able to find it. Next time I guess I will just have to ask.
  7. mcgyvr
    Oct 15, 2009
    4,783
    973
    They do sell reduction nozzles for typical heat guns that takes it down to a .375" cylinder nozzle.. I still think the hot air rework station is a better solution though.. Like the sgt said even a lighter works for shrink tubing..but its impossible to use a lighter to remove smt parts. :)
  8. c0de3
    May 1, 2009
    50
    Folks,
    Thanks for all the ideas/thoughts. I have a HF not too far away, 30 minutes or so, maybe I'll check that out. I can also look on ebay for the rework station. Anyone have experience with any specific unit they liked or disliked?
    @spinnaker: just so I'm clear, are you saying you haven't had any gun overheating issues, or that you haven't had any issues using the gun to remove SMT components?
    - C
  9. kelvinmead
    Member
    May 15, 2011
    30
    am i the only one who uses a soldering iron for heatshrink? not the tip mind, the bit you burn your finger on!
  10. spinnaker
    Oct 29, 2009
    5,062
    1,159
    I have not yet used it for smt but plenty of through hole which I imagine is harder to desolder.
  11. spinnaker
    Oct 29, 2009
    5,062
    1,159
    I often use the part where the tip is inserted.
  12. MrChips
    Oct 2, 2009
    12,622
    3,451
    For shrinking heat shrink tubing I use a paint stripper heat gun.
  13. spinnaker
    Oct 29, 2009
    5,062
    1,159
    I think that is what Wookie and I mean when we suggested the Harbor Freight gun.
