heat problem in AD811
Discussion in 'Homework Help' started by Rockzinstruz, Jul 30, 2012.
  1. Rockzinstruz
    Jul 13, 2012
    Hi...
    I designed the amplifier circuit with the gain of 10 using AD811.while amplification this IC produces the heating effect if I use this IC for a long period of time IC becoming a too hot.I couldn't find the reason for this .
    I need solution for this .Please suggest the ideas for this probelm.
    With thanks,
    Rockzinstruz
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
    Without a schematic, we can not tell you what the cause is of the heating.
    Please post a schematic.
    Bertus
  3. Jony130
    Feb 17, 2009
    3,991
    1,116
    You don't give as enough information. So we are unable to help you.
    But I suspect that you have a problem with parasitic oscillation.
