#12, ok. Just wanted to make sure you weren't trying to convey something to me that I wasn't getting.
cmartinez: There was 20-40 amps flowing through a cable to the loose bolt. The looseness caused increased resistance, and thus heat. Lots of it. It was finger tight onto a lock washer so very little actual metal contact was occurring.
I've built 4 different variations of a positive gate driver. I'll have test results tomorrow. I'll post the design that is getting the best actual rise/fall times as measured, not simulated.
One point that I would add to this is that the battery voltage coming in is dirty. I've seen spiking up to 20V+ above the nominal voltage. So, I went with products that had higher maximum voltages. Anyway, once I see the results, I'll post the designs for comment.
I appreciate the feedback guys.
