Heat issue with EMP Generator
Discussion in 'The Projects Forum' started by headros, Feb 27, 2014.
Thread Status:
Not open for further replies.
  1. headros
    Feb 10, 2014
    5
    I am a novice building an EMP generator from this schematic. I was unsure of the coil I needed, so I took one from a linksys carcass. Can this coil make do? (see photos) It seems like it works when powered on, my EMF meter goes over 120millgauss pointing near the coil and I get a signal on the oscilloscope. The IRF840 gets over 200F with the heatsink.Is it suppose to get this hot or do I need better heat disipation? I am using the 1uF capacitor to create a 156Hz - 10kHz pulse. When I use the .1uF cap i can clearly hear the pluse sound coming from the coil. Thank you for any tips or suggestions.
    Here is a demo video
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    A real EMP requires a nuclear detonation. This is like a small toy popgun -- EMP indeed.
  3. tcmtech
    Nov 4, 2013
    2,113
    1,752
    I would say that's being generous on the description.
    I don't even see an actual output coil or is the torrid inductor it? If so.... HUH? :confused:
    shortbus likes this.
  4. headros
    Feb 10, 2014
    5
    I was not sure what type of coil to use. After searching the web I believe a coil like this is needed, hopefully someone can confirm this for me.
      File size:
      214.4 KB
      34
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    I'm not too worried about the EMP you will generate, but in general they are against ToS. Therefore, I am closing this thread.
    This from the ToS (Terms of Service):
Thread Status:
