Heat Detector Circuit
Discussion in 'General Electronics Chat' started by vick5821, Apr 29, 2012.
  1. vick5821
    Jan 27, 2012
    54
    Hey, having some problem in this type of circuit. Can I use LM 35 as the heat sensor ? Or any other sensor which is better to sense heat from a distance ? HELP....URGENT :(
  2. debjit625
    Apr 17, 2010
    790
    186
    What type of circuit?
    It’s a temperature sensor, and heat could describe by temperature so yes LM35 could be used.
    Any temperature sensor can sense heat, if you keep it away from the source of heat then it will measure the ambient temperature of the heat source , obviously the measurement will depend on how far you are measuring.
    Thermocouples could also be used as temperature sensor.
    Good Luck
  3. vick5821
    Jan 27, 2012
    54
    I am doing heat detector circuit..
    But LM 35 I need to bring the heat and touch the boayd of LM 35 then only the voltage changes?
  4. KMoffett
    Dec 19, 2007
    2,584
    234
    As far as I know almost all heat detectors are contact or ambient (air contact). The only heat detectors that measure from a "distance" are infrared optical sensors.
    Ken
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  6. MrChips
    Oct 2, 2009
    12,624
    3,451
    Hey Bert,
    your first link to bohr.physics.hku.hk is broken.
  7. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    I have exchanged it for an other one.
    Bertus
