Heartbeat Sensor 8051
Discussion in 'The Projects Forum' started by johnjameson2011, Jun 5, 2014.
  1. johnjameson2011
    Feb 17, 2011
    12
  2. paulktreg
    Distinguished Member
    Jun 2, 2008
    622
    124
    The item you've linked to consists of a lightsource, the LED and a photodetector and gives a purely low level analogue signal when correctly driven. I've haven't any experience of the Arduino and can only presume it has signal processing and ADC built in? The device you've linked can't be interfaced with the 8051 without processing electronics.
  3. absf
    Dec 29, 2010
    1,493
    374
    I am sure it can be used on any mcu. First you have to go to Arduino site and see how it is connected to the arduino.
    Looks like it is just a pair of IR transmitter and IR receiver. Your finger would be placed in between the two. You can actually make and try it out yourself.
    Dont think there's any chip underneath the PCB. The 3 pins must be Vcc, Data and Gnd.
    Here is a better sensor from https://www.sparkfun.com/products/11574 where the schematic is included.
    Allen
    johnjameson2011 likes this.
  4. johnjameson2011
    Feb 17, 2011
    12
    Ya the 3 pins and Vcc,Gnd are the 3rd,Out goes to the Arduino analog input.
    So I presuming I could connect it to an 8051 chip and then program that accordingly
