Heart Rate Pulse
Discussion in 'The Projects Forum' started by quantumlab, Jan 27, 2009.
  1. quantumlab
    Dec 4, 2008
    19
    I am building a heart rate sensor. I have already built a heart rate receiver circuit and i would like to input the pulse into the ADC of my pic microcontroller. I have written the code to display the analog voltage on the LCD. However i think that the pulse is too fast for the LCD to display it. Is there a way of slowing this down. Because i would like to know if the PIC is receiving the pulse. I am using PIC16f887.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Sure, you take in the data at the real-world rate, and display the converted numbers at whatever rate you can keep up with. This isn't too likely to be meaningful. If you had a graphics display, you could scroll the waveshape across it.
  3. quantumlab
    Dec 4, 2008
    19
    Thanks for your help. I am now trying to write the code to calculate and display the heart rate in BPM. I am using MikroC. I am using the MikroC example to display an analog voltage on the LCD. And i would like to adapt it to show heart rate.
    The heart rate pulses occur on average over once a second. I have written the following code but cant quite manage to get the LCD to display my value. my code i have added is in bold. When a pulse is picked up the voltage is at least 1 volt. Therefore when the volts digit is great than 0 i would like to record the time on the counter. i would like the counter to carry on and then record the next pulse time. then i would like to use the time interval to calculate the bpm. does this sound okay? i am unsure of whether the counter is written correctly? and also i cannot display the value? Could you please help me in any way possible? Thanks
    unsigned char ch;
    unsigned char heart_rate_char;
    unsigned int adc_rd;
    unsigned int T1;
    unsigned int T2;
    int Heart_Rate;
    char *text;
    long tlong;
    unsigned counter, tmp; // counter variable, temporary variable
    unsigned short T1_count = 0; // Timer1 counter
    void main() {
    INTCON = 0; // disable all interrupts
    ANSEL = 0x04; // Configure AN2 pin as analog input
    TRISA = 0x04;
    ANSELH = 0; // Configure other AN pins as digital I/O
    Lcd_Config(&PORTB, 4, 5, 6, 3, 2, 1, 0); // Lcd_Init_EP5, see Autocomplete
    LCD_Cmd(LCD_CURSOR_OFF); // send command to LCD (cursor off)
    LCD_Cmd(LCD_CLEAR); // send command to LCD (clear LCD)
    text = "Heart Rate"; // assign text to string
    LCD_Out(1,1,text); // print string a on LCD, 1st row, 1st column
    ADCON1 = 0x82; // configure VDD as Vref, and analog channels
    TRISA = 0xFF; // designate PORTA as input
    while (1){
    adc_rd = ADC_read(2); // get ADC value from 2nd channel
    tlong = (long)adc_rd * 5000; // covert adc reading to milivolts
    tlong = tlong / 1023; // 0..1023 -> 0-5000mV
    ch = tlong / 1000; // extract volts digit
    LCD_Chr(2,9,48+ch); // write ASCII digit at 2nd row, 9th column
    /// Heart Rate ///
    for (;;){
    T1_count++ ;}
    if (ch > 0) {
    T1 = T1_count;}
    Delay_ms(50) ;
    if (ch > 0) {
    T2 = T1_count;}
    Heart_Rate = 60 / (T2 - T1) ;
    T2 = T1 ;
    heart_rate_char = (char) Heart_Rate;
    LCD_Chr_CP(heart_rate_char) ;
    // LCD_Chr_CP('.');
    // ch = (tlong / 100) % 10; // extract 0.1 volts digit
    // LCD_Chr_CP(48+ch); // write ASCII digit at cursor point
    // ch = (tlong / 10) % 10; // extract 0.01 volts digit
    // ch = tlong % 10; // extract 0.001 volts digit
    // LCD_Chr_CP('V');
    // Delay_ms(1);
  4. quantumlab
    Dec 4, 2008
    19
    Hi i have spent three weeks trying to get this code to work. still not working i need help please. This is my code, i dont think 'Count' is incrementing correctly.
    unsigned int temp_res;
    int i;
    int T1;
    int T2;
    int T3;
    int Count;
    int Heart_Rate;
    char Heart_Rate_char;
    int x;
    int y;
    void main() {
    TRISA = 0xFF; // PORTA is input
    // TRISB = 0x3F; // Pins RB7, RB6 are outputs
    TRISD = 0; // PORTD is output
    TRISC = 0x3F;
    do {
    Count=0;
    // Loop:
    Count=Count+1;
    temp_res = ADC_Read(2); // Get 10-bit results of AD conversion
    PORTD = temp_res; // Send lower 8 bits to PORTD
    PORTC = temp_res >> 2; // Send 2 most significant bits to RB7, RB6
    if (temp_res > 100 && (T1=0)){
    T1=T1+1;
    T2= Count;}
    // Delay_ms(50);
    if (temp_res > 100 && (T1=1)){
    T1=T1+1;
    T3 = Count;}
    if (T1=2){
    Heart_Rate = 60 / (T3 - T2) ;
    T1 = 0 ;
    T2 = 0 ;
    T3 = 0 ;
    Count = 0 ;
    Heart_Rate_char = (char) Heart_Rate;
    x = (Heart_Rate/10);
    y = (Heart_Rate%10);
    ANSEL = 0;
    ANSELH =0;
    LCD_Cmd(LCD_CLEAR); // Clear display
    LCD_Cmd(LCD_CURSOR_OFF); // Turn cursor off
    LCD_Chr(1,2,x+48);
    LCD_Chr_CP(y+48);
    LCD_Chr_CP(' ');
    LCD_Chr_CP('B');
    LCD_Chr_CP('P');
    LCD_Chr_CP('M');
    // goto Loop
    } while(1);
