heap memory in C
Discussion in 'Programmer's Corner' started by cktcrazy, Apr 10, 2011.
  1. cktcrazy
    Mar 27, 2011
    16
    hello
    i have some doubt about heap memory. i know when we allocate memory at runtime i.e.dynamically the memory allocated in the heap area.i am a firmware programmer workin in C. is memory allocation is required when we are working on some operating system because in firmware we directly write program and dump the hex file in target hardware ?????? here we don't have any heap memory area in microcontroller or something like heap momory area is there in RAM . i'm bit confused......... i guess no........
    plz help me in this regard
    waiting for your response
    regards
    cktcrazy
  2. debjit625
    Apr 17, 2010
    790
    186
    Heap memory also called free store is nothing more that a logical memory mapping in system's memory,you can create heap in microcontroller's RAM region but its useless in microcontroller because heap memory is normally related to a large chunk of memory allocated at runtime and microcontrollers have really very small amount of memory and normally they are not used to run Real Time Operating System(not large enough to support dynamic memory allocation) ,thats the job for microprocessor where we connect external memory and that makes it large enough.
    Good luck
  3. mjhilger
    Member
    Feb 28, 2011
    119
    16
    What he said! Seriously, if you are going to program in C for microcontrollers, you better get used to looking over the assembly and/or the mem map created by the compiler to understand its memory usage. Each compiler operates a little different and especially on microcontrollers with the very limited memory, they play a lot of tricks to squeeze efficiency out. Malloc is not a good use of memory in uC. If you write a few very simple "C" programs and then spend an evening looking at [the dump of your program] each assembly command that was used to implement your program, you will get to see how that compiler is using the memory and registers. It can help you write better/faster code to understand the implementation.
