Headset Connector
Discussion in 'General Electronics Chat' started by frenchie29, Feb 6, 2010.
  1. frenchie29
    Thread Starter Active Member
    Nov 28, 2008
    134
    I have to terminate this sennheiser headset to a 4 pin XLR
    http://www.sennheisernordic.com/sennheiser/products.nsf/resources/FAA23B094A1369EEC12574330043388A/$File/HMD_HME_46_ATC_US.pdf
    Page 11
    What is the Microphone LO, Microphone Hi and same with the Audio Hi and Audio Lo??
    Impedence?
  2. MikeML
    Oct 2, 2009
    5,450
    1,066
    Lo is the designation that wire is to be connected to the "ground" of the respective audio circuit, i.e. Mic Lo ties to the Mic ground and Audio Lo ties to the headphone amplifier ground. These are likely to be kept separate.
    Do you have a pinout of how to wire the XLR connector? Are you using PTT?
    According the headset PDF, there are several mic options. Which mic do you have? All the headphone impedance says 300Ω "per system", so I'm guessing that it is 600Ω per earpiece, since they could be wired either mono or stereo.
  3. frenchie29
    Nov 28, 2008
    134
    I will have to check if it's a dynamic or a condenser mic. I hope it's dynamic the base station that I need to hook it up to only has a dynamic option. No no PTT.
    The base station is a Telex RTS Digital Intercom similar to that one
    http://www.rtsintercoms.com/product.php?id=90007497XXX-LK
    And here's the actual headset that we use for now
    http://www.intercomheadsets.com/product.php?id=300852200
    I was thinking of using the same wiring as that headset but that one is mono only so I would put the L-R wire on the same XLR pin.
    http://www.intercomheadsets.com/binary/PH-88%20Technical%20Data%20Sheet.pdf#page=2
  4. MikeML
    Oct 2, 2009
    5,450
    1,066
    Yes, just parallel L and R.
  5. frenchie29
    Nov 28, 2008
    134
    Here's what I have so far. I'm not to sure about the L-R from the headset Do I have to short pin 1 and 4?
    XLR 4 PIN************* HMD 46 colour wires
    Pin 1 ground --------------Screen
    Pin 2 mic (-) --------------blue (mic LO)
    Pin 3 mic (+)--------------red (mic HI)
    Pin 4 audio Left----------- audio HI Left & audio HI Right???????
  6. frenchie29
    Nov 28, 2008
    134
    Or
    Pin 1 mic (-) -----------------blue (mic LO)
    Pin 2 mic (+)-----------------red (mic HI)
    Pin 3 audio Left(-)----------- brown&green (audio LO Left & audio LO Right)
    Pin 3 audio Left(+)-----------white&orange (audio HI Left & audio HI Right)
  7. MikeML
    Oct 2, 2009
    5,450
    1,066
    It's the second one. The screen (shield) goes to body of the plug.
  8. frenchie29
    Nov 28, 2008
    134
    Ah I see the drain tab on top of the XLR connector?
    I did alot of mic cables but never used the drain tab.
    Thanks!!!
