Hi there!
I have a small problem with my "weekend" project, I've been working on for almost 3 weeks now. But let's me start from the beginning. I'm not a electronics specialist/technician etc., but I know the basics and have some experience in DYI projects. I'm also a pilot (non-commercial), and got tired of all those cables I have to use in my cockpit in order to listen to some music while flying. So I decided to permanently install a small MP3 player INSIDE my headsets. Everything worked out great. It looks good visually, it works like a charm. With the ANR on inside my room sounds amazing but....
....The tiny-tiny MP3 unit (Polaroid PMP80-2) output power isn't strong enough for in-flight use in a piston airplane. It's just too quiet. So I figured I can hook up a small headset amplifier to it to boost the signal. The level is acceptable and the battery running time too, but there's still one problem I'd like to solve.
I already have 5 momentary switches mounted to the headset to control MP3 unit, and I don't really have a room for more. I'd like to create a small (literally has to be tiny) circuit to turn on the amplifier automatically ON when I'm playing the the music and OFF when the player is off. I could hook up one momentary switch to both, but power-on-off switch on my MP3 player acts also as PAUSE/PLAY button (you have to hold it like 2 sec to turn the unit off).
I was thinking about a couple of solutions:
1) There'a a 3V LED diode that stays lit when MP3 unit is in use. Use some kind of current/voltage/opto sensor to detect when it's on and a tiny relay to switch the power on to the amplifier. Plus I would have to hack the amplifier somehow to stay ON whenever the power is applied to it.
2) Audio signal detector on the audio line to switch the relay on-off.
3) Some kind of switching IC sensing when I'm pressing power off button for 2 sec and turns off the amplifier for me.
I just need a push into right direction and I would be very thankful for more detailed solution to my problem. It has to be physically small, postage stamp size or less.
I included some photos and a simple diagram. (amplifier is the Fiio E5 - not shown on the pictures)
